![]() Join Date: May 2014
1JZ VVT-I IS300 | Manual - A/C - BN Kit - Cage & Full Black interior - Suspension Mo
2004 IS300
1JZ GTE VVT-I w/ working AC Clean title Pickup in Jacksonville, FL or you arrange Transport $10,000 Will consider trades plus cash on your end. TEXT ME at 904 505 5774 ![]() ![]() ![]() ![]() ![]() https://imgur.com/DXCZA0x Video of the car in drift ^^^ Specs: (Info on bottom) 1JZ bone stock with 170 compression across all 6 FMIC 3" Exhaust with v-band and tucked high into chassis ACT Clutch and lightweight flywheel Recently serviced all fluids, spark plugs, and vc gaskets BC Adjustable Coilovers KFD FUCA's Heat-maker Knuckles for responsive steering & more lock New tie rods Working E-Brake for drifting Adjustable rear arms ARP extended rear studs Welded differential (Can include an LSD if preferred) New hawk brake pads Full Black interior in good condition A/C and heat work great Sparco Evo 2 black bucket seats driver & pass. Handbrake Drift Button Autopower Bolt-In Cage Double Din bluetooth radio Power functions work Power windows/sunroof BN sports style Kit Chargespeed authentic fenders Custom vented style hood LED aero mirrors Clear Headlights with black housing Aftermarket Tail lights Aftermarket exhaust tip Shaved body line Pulled rear fenders Amazing car. Comfortable to drive on the street, and drifts amazing. AC blows ice cold. I have over 14k into this car. It currently runs and drives, but at idle appears to have a slight vacuum/boost leak that I haven't had time to diagnose yet. The transmission also is making noise at a standstill, therefore I believe it should be replaced. Hood has a small spot that needs touch up paint, and the rear bumper needs to be sprayed as well. Because it needs this work and I don't have the ability to invest more time and money into the car, I will take $10,000. Either replace the W58, or swap it out for a beefier transmission. I have an AR5 transmission swap (updated R154) with R154 bellhousing already bolted and custom clutch and flywheel setup I can include for the right deal. Will come on stock wheels, or I can include 18" rays Genomes for the right price. I also could include a brand new fineline tuning spare BN kit, and authentic ganador mirrors for extra. Contact me with any questions. Serious parties only. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
