#31 |
#32 |
i kinda have the same problem except i have a 91 hatch stock ka-de
when i press on the brakes my idle drops to like 400rpm. Same when i decelerate, wtf could it be? I think i might need a new alternator, is there any place i can buy a good one?
street dancer. |
#34 |
did you? my car doesnt die. different scenario and my alternator is fine. I'd assume if it was a vacuum leak then my car would die
street dancer. |
#36 |
#37 |
![]() Join Date: Aug 2010
i can almost guarantee that most situations involved with your car bogging or dieing or any rpm change when hitting the brakes is because of vacuum leak!
Every topic i have seen about this has lead to vacuum leak. I had the same issue with my car and it was vacuum leak. the OP had the same issue and it was vacuum leak! its vacuum leak! |
