![]() Join Date: Aug 2017
What to change while 5 speed tranny is out of car
I'm in the middle of doing a 5speed swap to my s13. Anyone have any suggestions on what things I might as well change before it's in the car, to save my self headaches in the future?
Rear main seal, clutch fork pivot ball (where your clutch fork rests) and reinforce your clutch fork which will help from bending due to mad clutch kicks.
![]() Join Date: Jun 2003
Trader Rating: (129)
also, delete the damper box on the clutch hydraulic line, replace the factory line with a stainless braided line, and get a new master and slave at the same time
replace driveshaft with a 1pc replace trans mount with an aftermarket one |
![]() Join Date: Nov 2012
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 7 reviews
replace your rear trans seal, and replace the front trans seal and gasket also. get a cheap daikan clutch slave off enjuku or fr sport
The Game you lose haha |
Yea get rid of the clutch dampener. After awhile you won't notice the difference in pedal feel. Also it will save you headaches from clutch bleeding.
Sent from my FRD-L04 using Tapatalk |
