AFC not getting TACH SIGNAL
I know a few are gonna flame for me using an AFC......
I installed the AFC NEO and everything is working fine its just that its not getting a tach signal and i dont want to tune it with it only going by the TPS.. just need some advice.. ***Have a SOHC Cluster in the car..also wanted to know if me not having the DOHC Cluster effects the AFC also not to read RPM'S*** THANKS.. |
![]() Join Date: Dec 2007
![]() ![]() ![]() ![]() Feedback Score: 16 reviews
check the wire connection on the tach signal wire and triple check to make sure both wires are the correct color
good luck
Banana boat chronicles |
its definetly the wire that reads from the ecu.. you need to check that...
www.massimopower.com PH: 1(951)402-5386 EM:[email protected] Special Thanks To: www.aeperformance.com www.domospeed.com/blog For Their Continued Support |
| 550cc, afc, neo, tach, z32 |
