93 hatch wiring problem
hi im new to here but i have a 93 240sx hatch an it has a ka24de motor but i have an s14 harness possibly? so i was told, everything i can hook up is except for 3 clips 2 near intake manifold a white clip with 2 wires coming from it red and black wires then theres a yellow clip with 2 wires also red w/green an a red w/white wires, an theres a clip near my throttle body that has no where to clip in at an the only things on my motor not clipped in is a purple clip an brown clip on my intake manifold someone please help me im new to nissans
![]() Join Date: Dec 2008
Pics or GTFO!
Just playing. Take a full photo of the engine bay and then of the connectors. That would help a lot I'm sure. Also the harness for the engine doesn't have to be auto. Could be from a manual as well.
1990 Nissan 240SX w/KA24DE - New project 1984 Mazda RX-7 GSL-SE 13B |
white clip
![]() has a solid red wire an a solid black wire yellow clip ![]() has a red wire with a green stripe and another red wire with a white strip they come off my engine harness itself and are located near the rear of my lower intake manifold now these 2 pics are sensors that are on my intake manifold the ends of the wires (i took the clips from a junkyard off another nissan) purple clip has a yellow with a black stripe wire and it has a solid black wire ![]() an the brown clip has a light blue wire an either a white with green stripe or yellow with green strip coming from it both plugs are on my lower intake manifold please someone help me lol |
Sounds like its all for the emissions equipment. I couldn't tell you where they go though. Sorry.
Just buy another harness for the whole intake manifold. It separates from the engine harness.
where does it disconnect at? an if i could get told what clips the yellow an white are an the purple an brown are i would cut an splice those 4 wires so i dont have to buy anything
Ok first off I don't feel like reading everything you posted before this haha. but I know wiring when it comes to s13. So there's two harnesses. One connects transmission alternated starter etc. that's the lower harness Then there's upper harness fuel injectors temp senser maf senser etc. which one are you talking about. And an s14 harness would change cuz there's an obd 1 and obd 2 versions of s14. So let's start off with what harness are you talking about lower or upper?
#17 |
Just for clarification, how many pins does the plug for your distributor have?
#19 |
I just thought of something it can't be an obd 2 harness cuz there would be no dizzy plug and those plugs look like the ones that get connected to the back portion of the motor in between the firewall and head.
#21 |
![]() Join Date: Feb 2010
If the harness on your car is hacked up get another s13 harness. Its also unlikely anyone would take the time to install an s14 wiring harness to an s13 ka.
#23 |
ok well i bought an s13 harness from another 93 hatch that just so happened to be auto only thing is that the kid cut 2 main plugs? so he could use it on his sr s13 an the purple an brown plugs are a sub harness
#24 |
Dude auto or stick its the same harnes the only plug that gets added is the tps trans plug. You didn't need to buy another one. Like I said earlier those plugs look like they go to the emissions stuff in the back of the motor.
