Old 07-29-2019, 05:07 AM   #1
fknjexx
fknjexx is an unknown quantity at this point
s13 S13 headlights turns the car off
Hey guys,
My partners car has been acting up lately ever since she got her tyres fitted. Car idles fine but as soon as the headlights are turned on the car loses power and the EGI relay starts to buzz. Any ideas on what it could be?
Battery has been replaced recently, got new alternator installed (multimeter reads 14.3 when running), fuel pump has been changed and tested there was pressure going through, & checked all fuses which seem to be intact. Not too sure if it would be another electrical issue or possibly just a loose ground...
Here’s a video:
Car: Nissan Silvia PS13 SR20DE
https://youtu.be/QFmvciStXy4
fknjexx is offline   Reply With Quote
Old 07-29-2019, 06:12 AM   #2
Super_OK_S13
Super_OK_S13's Avatar
Super_OK_S13 is a glorious beacon of lightSuper_OK_S13 is a glorious beacon of lightSuper_OK_S13 is a glorious beacon of lightSuper_OK_S13 is a glorious beacon of lightSuper_OK_S13 is a glorious beacon of lightSuper_OK_S13 is a glorious beacon of lightSuper_OK_S13 is a glorious beacon of lightSuper_OK_S13 is a glorious beacon of lightSuper_OK_S13 is a glorious beacon of lightSuper_OK_S13 is a glorious beacon of lightSuper_OK_S13 is a glorious beacon of light
sounds like a short, unless you relocated the harness away further above where the tire could rub..
check the harness behind the fenders for rubbing through.
Super_OK_S13 is offline   Reply With Quote
