positive terminal wiring getting hot s13
Welp, I replaced the 10a fuse to eng cont. on the fusebox because I was getting a charging light and a buzzing sound. It fixed it but the wires going to the positive terminal started smoking. Here are some pics:
Also the red thing came with my wiring specialties lower harness but never installed it. (it has a lock so I don't forget where I put it lol) 20200216_140029 by Jesse Villa, on Flickr 20200216_140444 by Jesse Villa, on Flickr 20200216_150151 by Jesse Villa, on Flickr |
![]() Join Date: Oct 2007
Is that speaker wire????!?!?
I would remove those clear wire and connect the white wires straight to the terminal connector You can replace the factory terminal with a new battery terminal and just connect the wires straight to that too ![]() Sent from my iPhone using Tapatalk
Yeah its some gross 16 guage speaker wire :/ (it used to be someone's project). I'm going to go the junkyard tomorrow to cut some of those connectors to plug into the red thing on the battery terminal, for those 2 white wires, do i just crimp them into one bigger wire? Or should I just say screw it and relocate the battery to the back?
Just came back from the junkyard just to find out the idiots cut out the terminal harnesses on ALL the cars. Also scoped out home depot and o'reilly's on the way and found nothing
I went with andisan's suggestion and bought terminal. Does it look okay, kinda worried before I start my car again.
20200217_181905_1581992633361 by Jesse Villa, on Flickr |
That’s 100x better then speaker wire
Trust me That’s how I have mine set up and no issues at all Sent from my iPhone using Tapatalk
