#62 |
Looking great man!
Contact: [email protected]; 407-281-1223 +25 |
#63 |
Just curious, whats the rationale for running no intercooler and such a short charge pipe? Lack of space or some other reason?
WTB: boot cover bag, vert roof header garnish, vert roof header cap |
#64 | |
Im not running an intercooler because I intend to run 100% methonal at the track and I'm hoping that will keep my temps down enough to not need an intercooler. |
#65 |
How will that do on the street though, when you're running the 93 tune?
#66 | |
WHat do you guys think? I've never had a non-intercooled setup, just trying something |
#67 | |
- run e85 - run 93/meth combo - lower turbine side boost pressure I'm sure you could play around with lots of different configurations, but in my very inexperienced/unprofessional opinion, I'd lean towards running e85 instead of 93, if it's available in your area. Less complicated than running 2 separate meth systems, and potentially more cost efficient (depending on how much street driving you plan to do).
#68 |
Or, if you're worried about space/packaging you could do a water to air intercooler set-up
#69 | |
2nd i have a boost controller, and on the street i've always had to have the boost pretty much all the way down anyhow I think it will be fine, gonna find out either way. |
#70 | |
Not worth the money to et ratio to buy a badass air to water intercooler and put it all together. |
#74 |
Pics seem to not be working for me, I'm sure it's bad ass though!!!
#85 |
Car is working very well right now, 1.30 is the best 60', q45 diff, q45 pass axle, tt300zx driver axle, s13 subframe, IDS all around, ISIS bars in back. Its about .04 away from being where I set my pretty lofty goal. I'm extremely surprised at how fast this car is. For some thrown together stuff in my garage its fast ![]() |
#86 |
Nice man,
We've gotten down to 1.20 60' on the Q45 diff, but that was with a Kaaz LSD and with the S14 subframe. Our new set-up is a explorer 8.8 with custom axles and a spool, hopefully we can hit into the teens on the 60'. I'm curious to see how long your diff lasts, we were making 1150hp at the wheels through a powerglide and spraying the hell out of the car on launch and it lasted about 5 good hits before is stripped the ring and pinion. |
#87 | |
#88 |
I dont know what the difference in the s13 and s14 subframes are. My subframe is all stock, i have some sikky solid bushings but I haven't put those in yet. It still drops down like an 1" when you jack up the rear.
THe q45 diff is just a piece I got out of one of our local junk yards, didnt really look at it, just slapped on my s13 cover, popped it in the car and went racing. I think i put some of that really stinky friction modifier that you run in the LSD 8.8 ford stuff in |
#89 | |
#90 | |
It is a bolt on for the S13 chassis though if you ever wanted to upgrade. |
