![]() Join Date: Sep 2010
Trader Rating: (41)
![]() Feedback Score: 41 reviews
Hello everyone! Been a member of Zilvia for quite sometime and like to think I've built some pretty cool s-chassis in the past. This thread is to document the build of my '99 Silvia. Thank you to Charleston Performance Solutions for giving me access to their dyno. So now I'm able to share how much power is gained/loss with each modification.
I also keep my Facebook page updated to document the build aswell: S15 Build Consider this an empty canvas. Stock as stock can be '99 Nissan Silvia Spec-S with 142,900 km on the odometer. Purchased from BLACKED OUT Motorsports on 4/16/2016. ![]() ![]() ![]() ![]() |
Trader Rating: (41)
May 2, 2016
After much research I finally ordered a set of my dream wheels from JDM California Motors. I'm not sure if I can contain myself during the 5-6 day arrival time. After much research I decided on a set of Fortune Auto 500 series coilovers with custom spring rates. Once again thank you to Enjuku Racing for the fast customer service and pricing! Here's a teaser of the wheels. ![]() |
Trader Rating: (41)
May 8, 2016
Attended Global Time Attack & Formula Drift over the weekend in Georgia. That's my 6th year in a row and it gets better every year! I hope to run in the enthusiast class next year with the Silvia. ![]() ![]() ![]() ![]() |
Trader Rating: (41)
May 9, 2016
I purchased a Nismo spoiler from a private seller on eBay and it arrived today. These are just some test fits. Not sure if I like it or not, but I'm sure it'll grow on me. ![]() ![]() ![]() |
Trader Rating: (41)
May 12, 2016
My Rays 57 PRO's arrived today, can't wait to see them on the car! They are 18x10/9 +22 Thank you JDM California Motors for the extra packaging and getting them here safely. ![]() |
Trader Rating: (41)
May 23, 2016
I was lucky and was able to find a set of R32 GTR calipers & rotors on Craigslist. Scooped them up from a GTR owner just 3 miles from my house. With a little cleanup, some new hardware and nice pads these will look at home on my car. ![]() Thank you GKtech for these quality caster, tension, camber & rear toe arms. Along with eccentric lock-out bolts and stainless brake lines for my newly acquired GTR calipers. ![]() ![]() |
Trader Rating: (41)
June 8, 2016
Late night delivery from the UPS man... Fortune Auto 500 series coilovers from Enjuku Racing. 9kg/8kg custom spring rates, nothing crazy but should be perfect on the street with light track use. ![]() Couldn't resist snapping a picture of it in the daytime after the coilover install lastnight. The GKtech control arms are going on tonight with possibly a bit more low once the springs settle in place. ![]() |
Trader Rating: (41)
June 13, 2016
Tonight I installed R32 Skyline calipers & rotors on the front. These are a direct bolt-in once you remove the dust shields and use GKtech R32 stainless brake lines. These are a cost effective upgrade from the single piston caliper and 280mm x 22mm rotor to 4 piston, 296mm x 32mm rotor. ![]() ![]() ![]() |
Trader Rating: (41)
June 14, 2016
Quick project today after work. I polished up the near 20 year old headlights using Chemical Guys All In One Polish + Sealant. Night & day difference, but did manage to scratch the front bumper while I wasn't paying attention. That's ok for now, I plan on having the car and new aero parts resprayed pearl white next month. ![]() ![]() ![]() |
Trader Rating: (41)
September 28, 2016
Spending sometime today modifying a DC2 lip to fit properly. I've seen a lot of poorly (very poorly) examples of this. However I feel like mine is getting pretty close to where it should be. Not sure if I'm going to keep it on, or not. ![]() ![]() |
Trader Rating: (41)
November 21, 2016
Had a great weekend running PDX at Roebling Road Raceway! Awesome weather for racing and camping out, look forward to bettering my lap times. Not bad for a 2,800lb car with 121hp spinning an open diff I think! ![]() ![]() |
Trader Rating: (41)
December 8, 2016
Over the weekend I swapped from the factory DE engine, 5 speed transmission and open differential to Spec-R components. Now running the SR20DET, 6 speed transmission with helical differential. Thank you to BLACKED OUT Motorsports for supplying a super low mileage, complete swap! On the original engine I made a whopping 121hp. With the factory Spec-R I'm sitting at a healthy 200'ish. ![]() ![]() |
Trader Rating: (41)
December 22, 2016
After installing the GReddy Racing Profec boost controller it needs to be dialed in for perfection. Rather than doing countless street pulls it's easier (and ticket free) to strap down at Charleston Performance Solutions. On wastegate pressure (7.5psi) it made 188hp/194tq. 10psi made 239hp/240tq and at 12psi made 247hp/258tq. Sounds like pretty healthy numbers with a completely stock car minus a cone filter. Excited to see how a 3" catless exhaust will flow over the factory 2" with a factory catalytic converter. The factory side mount intercooler was noticeably warm after each pull. An aftermarket front mount will definitely be used in the future. ![]() ![]() |
Trader Rating: (41)
December 27, 2016
It was time for the restrictive factory exhaust to go. I sourced a used Blitz Nur Spec catback from a local's S14 and installed it. Lined up and bolted up perfectly to the factory catalytic converter. Sounds proper, deep and anything but raspy! I'll get it back on the dyno ASAP to see if there was any gains. Spent some time on the dyno tonight to evaluate the performance gains after installing a Blitz Nur Spec catback exhaust. Roughly 14 horsepower gained and mainly in the top end. Two graphs shown: One at wastegate pressure and the other at 14psi. Note that I am still running the factory Japanese catalytic converter. ![]() ![]() ![]() ![]() |
| jdm, nissan, s15, silvia, sr20det |
