![]() Join Date: May 2011
![]() Feedback Score: 15 reviews
Oil in Turbo Elbow
Hi I have a stock S13 Sr20det Black Top. I was changing the 2 bolt gasket for the turbo elbow and noticed a little bit of oil in the 2 bolt elbow before the turbo and some in the stock intake (rubber). Is this a bad thing? Is the oil catch can bad or something? Help
Man w/ CTSV & a Car Seat
Oil in the exhaust side, more than likely the turbo seals are done. I'd pop the inlet and check for shaft play. If it moves up, down, left, right, it might still be good. If it goes in and out, turbo is done.
