![]() Join Date: Jul 2002
97 sr black top how much power should I see with 10 lbs on a stock turbine?
and should I adjust my fpr higher? Is anyone running 10 lbs whats your set up? |
![]() Join Date: Mar 2006
stock TURBO....and this has definitely been talked about many, many times.
So is it an S13 or S14 SR (does the valve cover have a slanted part toward the back?). S13SR comes with T25, S14 comes with T28. S13SR with T25 @ 10 psi, maybe good for 215 hp or so to the wheels S14SR with T28 @ 10 psi, maybe closer to 245 hp to the wheels just my estimates
![]() Daily driven |
