95 S14 wiring question
I recently finished my sr swap. I have a 95 240sx se w/o abs and I swapped a 95 SR20DET in. I did the wiring myself and everything seems to be working except the fuel pump. All the gauges, lights, power everything except the pump. I tested some of the wires left over, and on an eight pin plug in the engine bay, there is an orange wire, a brown wire, and a green wire that have power when the key is on. I am out of ideas as to what to check next. Do these wires have anything to do with it? The pump was also tested and there is no power to it. Could it be a bad fuel pump relay? Any help would be greatly appreciated because I need to get my car up and running. Thanks
![]() Join Date: Dec 2002
Black/pink, signal.
Black/yellow, feed. Buy/download an FSM and read it.
