#31 | |
![]() Join Date: Oct 2006
Yea. I haven't been able to update it until now. I was living in Hong Kong since Jan so the car was in storage. Finished installing a Mazworx intake manifold and ID 1000cc injectors. Next is removing the battery tray (yay, I hate these) and making the hole in the body larger for the 3in intercooler piping coming to the q45 throttle body. |
#34 |
Not at all, once you have one in your hands you will see clearly why
IntensePower.com 480-635-8888 Setting World Records Daily! S13/S14 Tailight Specials Stance Coilover Special Kouki Headlight Special |
#35 | |
While setting up the base map, maxed out the fuel pump (OEM R32 GTR). So I had to order a surge tank and Bosch 044 pump. I'll update this once everything is installed. ![]() |
#37 |
Geno, can you talk a little about what you did with the breather line? Mine is almost touching the downpipe without a tube on the breather pipe...
![]() (My downpipe and manifold are coated with White Lightning) |
#38 |
![]() Join Date: Sep 2005
wow,are you like running e85 or something?or are you just doing it now for future needs,cuz the fuel setup seems over shot a bit??also,not sure your going to achieve anyhting other than lag with 3 inch pipe and a 30r..i have the full race t/s t4 setup,and my buddy has the powerlabs setup...personally i like the slightly larger runner diameter on the powerlabs stuff cuz im an hp junkie.your setup is freakin awsome!!i had a 30r kit a while back and it is freakin fun man,enjoy it!!!
oh,dont forget to post up some dynos if ya can..
" NEO VVL BABY FTMFW!" Originally Posted by shagspeed Dude if I made 500WHP on a 54C SR20DET back in 1999-2000 with old school technology .. This VET will T-BAG your RB engines |
#39 |
No doubt would love to see the Dyno's!
#40 |
![]() Join Date: Oct 2008
Bring this back from the dead as I just purchased one of these kits second hand.
I have a question...The person I purchased from threw in all his lines and the s14 waterneck. I am assuming you want to dump the "hot" (after cooling turbo) water back into the water neck. How do you cap off the original s13 line in the back of the block? |
#41 | |
#42 | |
![]() Join Date: Jun 2003
#43 | ||
Again, sorry for the late replies, its been a busy few months for me.
![]() Dyno is going to take place in about a month. I broke my trans road testing, and have removed the engine from the car to fix a few other issues. I'll make a new thread to document the process of installing the 350z gearbox onto the SR20DET using one of George's adapter plates, which can be found here. I unfortunately can't comment on getting the speedo to work with that swap, as I cheated by using a Racepak Logger dash which has a GPS based speedo. |
#44 |
Geno, may I ask a couple of questions on your setup?
I've purchased the same Powerlab kit and I want to know if it has a tendency to crack. Are the exhaust studs steady still? Did you saw expansion slots between the exhaust ports? And did you install any sort of bracing for the turbo? GT3071R, the manifold and downpipe weight too much, I doubt that the studs could withstand this weight. P.S. Sorry for my bad English. Thanks in advance. |
#45 | |
Breaking my gearbox when getting the car ready to dyno has been a bigger setback than I thought. I finally got my Z33 transmission back after having the bellhousing face cut down .5" Also during that time I sold my setup to a friend to have installed on his S15. I bought a second powerlab manifold, this time with the plans to use an EFR 7064 turbo so I could eliminate the need for two wastegates. Now I have to wait for my turbo which I ordered back in April. Right now, if you go by the EFR twitter page, we can expect to see them some time in October. ![]() |
