![]() Join Date: Mar 2006
*#*#WTB S13 Chassis harness HUD if applicable*#*#
Please help me if u can. I have been searching feverishly with no success locally. I need a chassis harness for my 93 dohc coupe. The car has HUD and since I havent had a lot of experience with HUD im not sure if the chassis harnesses are HUD specific. If they are is it possible to splice in my hud plugs to a non HUD harness. I need a harness in good shape one that hasnt been hacked to pieces. The previous owner of my car. Basically wired all of the white power wires under the passenger fuse box to constant 12 volt power. Im told some are switched and some are constant. This is what im told is drawing too much power at once keeping my car from starting. Any experience thoughts input and leads on where to find one is immensley appreciated. I have cash in hand and can be reached at 405-408-2905. Thank you
![]() Join Date: Feb 2012
Trader Rating: (37)
If your car was originally analog cluster and you want to go to HUD, all you need is the
HUD sub-harness. The chassis harness is not specific to analog or HUD. It all lies in the clusters sub-harness.
I like my bikes how I like my b¡tches...naked! 2014 Triumph Street Triple |
![]() Join Date: Mar 2009
It was my experience with my 89 sohc hatch, I bought a digital cluster, hud, and the sub harness (plugs into the cluster and dash harness) that i pulled for a 89/90 coupe. every thing worked as it should when I plugged it in. So by this logic you should be able to pull a non HUD harness and be fine. you will need the HUD/digital sub harness though.
#6 | |
![]() Join Date: Feb 2003
Trader Rating: (289)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 289 reviews
I have a body harness from a 93 Coupe, I can do $120 shipped. That would be much cheaper than paying a professional to repair the wiring.
The Digital Cluster has a unique(different than analog clusters) Dash Wiring Harness. It is something you can plug in and out. It is separate from the Body Harness that goes from Dash to Rear Tail Lights.
![]() Quote:
