I took my '96 240 in last thursday for an inspection and it failed because the rotors needed to be replaced and the front pads needed to be changed. I bought 4 new rotors and new ront pads and put them all on this weekend as well as a new outer tie rod end on the fr right that was screwed. Now after putting all the new parts on I have a bad vibration when I brake from any decent speed. It feels like their isn't a constant connection between the pads and rotors. Any one have any ideas on this. I need to take it back to finish the inspection and it won't pass like this. Thanks for any help.
Alignment will not cause a vibration...Some worn suspension parts, cheap rotors, wheel bearings, thickness variation or radial runout could be the cause.
Anyway, no drug, not even alcohol, causes the fundamental ills of society. If we're looking for the source of our troubles, we shouldn't test people for drugs, we should test them for stupidity, ignorance, greed and love of power. Looking for: JDM S13 OEM Sideskirts |
![]() Join Date: Mar 2003
lol yes a poor alignment will cause vibration. If your front tie rods are not aligned there will be a feeling in the wheel. He said he replaced the front tie rod end, have you gotten a alignment? if not i would go and get some to make sure the wheels are straight.
It wont be the pads, pads normally almost rest on the rotor. Check the t/c rods first. If the bushings are cracked get a new set. |
