Tire size predicament 235/40/18 front and 255/40/17 in back? LOL
right now I have shit tires on the front of my car: 225/40/17
decent tires on the back: 235/40/18 here's the problem... I have track day coming up in about 12 days and only have money to replace the front (17") tires. so I was considering putting on 255/40/17 tires on them and temporarily putting the 17s on the rear and the 18s up front. that way 235s are up front, and 255s are in back (granted the back wheel would be the smaller 17" but the height would be about the same). in a few more weeks, I'll replace the other tires on the 18s with 255/35/18s so I have 255 all the way around (time attack/track day). what do you guys think? any suggestions? |
Is it a car show or a track day? :p
track day. i don't care if it looks a little off. just wasn't sure the best route to go here...
Im gunn a go out on a limb and say you won't be the only one w smaller rims on the rear if it's a drift event. Who cares
I just like this information. keep it up.
Down grade go for a 15" rim so much sexy sticky rubber buy four new for the price of two 18"
Go functional I would never track 18" 16" cost of wheels is to much |
yeah, i just already had the 17/18" wheels :(
Why are you planning on changing rotating them? Why not keep the fresh tires up front to maximize grip and burn the used tires?
the fronts would be taller by .19" plus the rear rubbers might deflect or compress more from having more tire and less wheel, causing them to be even "smaller" though again itll only be a small difference.
if youre strapped for cash just buy slightly used tires on cl |
He's grip driving it, I'd stay away from used tires on CL. Last thing you'd want are some hard ass used tires in the back...
But my question is, don't know I'm just misreading it but, why do you wanna run 18s up front and 17s in the rear? Also, what width are they? |
^ you can find 'practically new' tires on CL if you look hard enough. most tires i buy have between 60 to 80 tread life left. about 30-60 each, balanced & mounted. i dont track it but you can still find tires with a lot of meat left.
and youre not misreading it. |
ahhh i see
UGG boots release clearance with with cheaper sacrifice but in high prominence
NfrTvk UGG Boots Clearance OutletPloYfe Ugg Boots Clearance PpeLwu UGG Boots OutletTcoAxv UGG Boots Outlet OchNjw UGG Boots Clearance OutletWxhVul Ugg Boots Clearance Outlet BtcEae UGG Boots Clearance OutletHzeLbz Ugg Boots On Sale ZqrUme UGG Boots ClearanceMlkCny UGG Boots Clearance Outlet Sale OlwBvj UGG Boots OutletSdqItv Ugg Boots Outlet Clearance Onsale XugXhv UGG Boots ClearanceJquXkd ugg boots on sale ugg boots outlet PguIxh UGG Boots Outlet ClearanceUreNmg ugg boots outlet clearance ugg boots on sale ugg boots outlet
| All times are GMT -6. The time now is 10:47 AM. |
