-   Archive and FAQs (#/f/forumdisplay.php?f=11)
-   -   S-AFC II translated manual (#/f/showthread.php?t=23870)
Speedfreak 02-14-2003 10:10 PM
S-afc Ii
I just got one and all the instructions are in Japanese. This afc is not sold in America yet. Does anyone know the wiring for it? I am putting it into a 1995 240sx with a red top sr20det.
Speedfreak 02-15-2003 10:06 PM
This is the AFC 2 It is not on the English site. This is the new afc that is not in America yet/
DarkRaptor42 02-15-2003 10:08 PM
the wiring should be the same as the original AFC.
Speedfreak 02-15-2003 10:11 PM
Ok. It is close but not the same. The new afc has more features included in it. I need to know what the additional wires are. Thanks for trying to help but bottom line is I NEED A TRANLATOR
Jeff240sx 02-17-2003 12:09 AM
Someone needs to scan the instructions. I can host them. Then, we'll FAQ them and help the community. Get to it!
-Jeff
Speedfreak 02-17-2003 04:32 AM
Here is a link to the Japanese site with the afc2. The instructions are there!!!! http://apexi.co.jp
aeontony 02-18-2003 02:19 AM
http://www.dweebsunite.com/1to14.pdf
(on my little bro's server)
You guys like? It's only pages 1 to 14 of the first manual..
I skipped the contents and the warnings. Most of the translation come in the final couple pages. I have to do some other work now so I didn't get a chance to read over what I translated. I'll do that when I find the time again.
Having to change the font of the pdf file line by line is what's taking my time. It uses MSP Gothic but I have WinXP Japanese installed, which uses MS Gothic. Does anyone know of a simple way to change the fonts of a pdf file? Or does anyone know where I can find MSP gothic??
Oh yeah, I had to crack the pdf file, too.
Speedfreak 02-18-2003 03:43 AM
I cant get it to work. Say something about encoding missing or corrupted. cmap or something. hmmmm
aeontony 02-18-2003 11:23 AM
sonovabiatch...hm. Must be my Japanese windoze environment.
Try these links out:
http://www.dweebsunite.com/manual_06.jpg
http://www.dweebsunite.com/manual_07.jpg
http://www.dweebsunite.com/manual_08.jpg
http://www.dweebsunite.com/manual_09.jpg
http://www.dweebsunite.com/manual_12.jpg
http://www.dweebsunite.com/manual_13.jpg
knightrider 02-18-2003 08:46 PM
can sum1 explain how the knock sensor on the afc 2 is supposed to be hooked up? does any1 know where the wire supposed to go? or which wire it is?
Speedfreak 02-18-2003 08:47 PM
Red power
green RPM singal
Gray Throttle singal
Brown Ground
Black Ground
Yellow air flow/pressure sinal out put
white air flow/pressure sinal in put
Purple knock sensor
u don't need the pink, orange(for
mitsubishi only), Blue (for skyline only)
knightrider 02-18-2003 08:50 PM
do ka's have knock sensors?
Speedfreak 02-18-2003 09:34 PM
yep
aeontony 02-20-2003 10:26 PM
As per speedfreak's request, here are the knock correction setup procedures:
http://www.dweebsunite.com/manual_38.jpg
http://www.dweebsunite.com/manual_39.jpg
I think I'm only going to do the pages people request..this takes quite more time than I expected (the part where I have to change the font for every single line individually). I want to do a good job for people so I won't start just dumping text into notepad. The end product is worth it, though. Looks almost like it came straight from Apex'i =)
ps: page 38 is something like 2 megs-must be all the pictures. Give it a bit of time. 39 is only 300k so it downloads almost right away.
pps: okay i downed the res a bit. it's 500k now.
knightrider 02-20-2003 10:29 PM
i think its cuz the rez is super high on pg 38, ah well, does any1 by any chance know which wire is the knock sensor wire on a SOHC, yea my afc 2 went on my ka24e, hehe, im jus playing around with it and learnin to use it til i blow this motor and build my turbo ka motor.
