-   -   Need Help s13 silvia gauge cluster install (#/f/showthread.php?t=521619)
1nasty240sx 06-04-2013 11:15 PM
So I have a 91 240sx which has the dohc gauge cluster. I am switching from hud/digital to a silvia s13 analog gauge cluster. My question is if I get a dohc cluster wiring harness will it work with my s13 analog silvia cluster? The Silvia cluster came with wiring should I use that or buy a analog wiring harness? Anyone that has done this can you lead me to the right direction as I do not feel like splicing my original harness to fit the silvia gauge cluster.
So Make Like 06-05-2013 05:47 AM
the hud/digital cluster uses a different sub-harness than the analog cluster. if you want to use an analog cluster, you will need the appropriate sub-harness.
1nasty240sx 06-05-2013 10:31 AM
thanks that is all I needed to know!
