-   -   what else can i do to my car? (#/f/showthread.php?t=6124)
07-30-2001 07:37 AM
ok i have fog lights (stock)...headlights.... intake.... strut bar.... stereo... neons.. ...rims... exhaust...i dont care for plugs or wires cuz i dont  think it would be worth it... what other inexpensive things can i do to set my car further apart? i dont want to spend more than a $100 i am a cheapie :biggrin:
(Edited by nismos14 at 8<img src="#/f/iB_html/non-cgi/emoticons/wow.gif" border="0" valign="absmiddle" alt=':0'>1 am on July 30, 2001)
West 07-30-2001 09:08 AM
I would certinly do some suspension mods. At least Springs and Shox. It will make your car look a whole lot better looking and it will out handle 98% of everything on the road.
Short Shifter (If your a 5-Speed)
Hi Flow Cat @ Rollhard.com
Interior Goodies
Sway Bars, if you buy one at a time.
What are you mojor goals of the car? Looks, Speed, or Handeling?
ca18guy 07-30-2001 10:19 AM
Also look into a set of pulley's, it's alittle more then $100 but worth a good 10 HP, unless you have alot of stereo equipment this would be a good mod.
justinc 07-30-2001 11:45 AM
I have a amp and 1 12inch sub is this a bad mod for me?
ca18guy 07-30-2001 12:45 PM
How much power is the amp pushing? &nbsp;I don't know how good the alternater is in a 240sx (i'm sure someone here knows) &nbsp;but i doubt it would effect it that badly. Anyone that has done the pulley mod could tell you if the felt it sapped the alternater.
transient 07-30-2001 02:55 PM
I think that the plugs and wires might be something to look into, actually a whole new ignition contol box if you're really looking to squeeze all the power you can out of the engine.
rabbit23 07-30-2001 03:45 PM
i have a 2x200w ppi, also a 4x100 ppi 2 10's and polk mids and highs, have the asp pulley installed and feel no problems.
West 07-30-2001 04:28 PM
The stock Ignition system is more then capable everything until you go with a Turbo or NOS setup. Although Plugs can be a worthwhile mod if your car has a lot of miles on it the plugs can get worn out causing them to not run at their max efficiency.
transient 07-30-2001 11:00 PM
Huh, I stand corrected <img src="#/f/iB_html/non-cgi/emoticons/smile.gif" border="0" valign="absmiddle" alt=':)'>
07-31-2001 05:08 PM
good suggestions anything else?
