pointers for autox
Hey what's up yall. Well Bbandit and I had our second autox and it was so much fun. By the way Bbandit is a very good driver without VLSD and a stock suspension. Well anyways I am getting better everytime, but I know there is a couple of things that I can improve on. I am starting to trust the car and pushing it more. But I think I am sluggish when I go through slaloms and existing corners. I was wondering what were some of yall's experience with your driving ability in the beginning of your autox or road racing days compared to how has it changed? I now it has changed for the better, but what were some of the things yall have change about your driving( nothing to do with suspension upgrades)?
Well the first time I raced I pretty much sucked. I didn't break my tires lose around corners or anything. I slowed down too much for turns and didn't use apexes at all. I just drove. I got last. The next autocross I went to I felt a little more confident with my car and it's limits. I also did a lot better and finished 12th out of 18 cars. Right now I feel more comfortable with my car after I've been driving it for almost eight months. I can also read corners better. I don't think I really need to change anything about my driving. I just think it comes with experience. Of course I could probably go to an HPDE and get educated, but I don't have that kind of money right now. To sum it up, you just need practice, and you need to know your cars abilities, as well as it's limits. This all will come in time.
I am still racing my 240 in stock classes so nothing has changed there. The biggest difference I have noticed over time is my awareness of things around me and ability to concentrate. The first time I raced I couldn't think about anything like apexes or even looking at my gauges (I have no idea how high I was revving). Since then I have been able to concentrate better and better on other things which has greatly improved my times. Outside of going to a school, the best thing you can do is to read up on techniques and try them, but most of all, get more experience.
fastpace
you're a great driver too man we all started as a newbie anyways besides i've been in this stuff for 2 years now but still i think i need more improvements tips and tricks : push your car to the limit and it takes time to know the limit of your car be smooth on the gas/brake pedals turn your wheel wisely.. dont overdo it keep the car balanced on the turn so it wont over/understeer brake BEFORE you enter a corner avoid braking while you turn (you could loose control) keep your speed constant on slaloms stay close to the cones (dont go too far) but yea.. i ate 7 cones last sundays for some reason.. those cones loves me i guess :p btw... here's some picture of the autoX http://www.maddphatt.com/autox20032/ warning: huge jpg files.. havent got the time to resize it... i have an exam tommorrow :( |
heh... i feel like I'm getting slower, and as the autoXes went on my mistakes have been getting bigger. It's probably because driving smoother usually means faster, which feels slower, so you're lured into a false sense of confidence, to you try to get on the throttle more, which spins you out since you were already near the limit.
biggest suggestion: pay more attention to how you're entering corners and where you're apexing them, rather than how fast you can get in between corners. |
#1 thing, REMEMBER the course, have a course walk or more than 1 if you can't remember it. So you have a idea on how the driving line before you go out.
Also, always look as far as possible, even u r cornering. Try it, and you will see the difference. -Pat |
Here's another tip: try to get a ride with a more experienced driver. Most of the guys at the autocrosses I went to last fall were more than happy to let me ride with them. It made me realize what I was doing wrong, and also that I suck.:p
Good Reading
I read Solo Secrets or something like that written by Henry Watts. Good book it helped me alot my first season. Remember slow is smoth and smooth is fast. I walk the course at least 3 times, you should pick places where you know you'll be WOT and on the brakes. Walking w/ an experienced driver helps also. They can help point out the fast line and the right apexes. I always remember which cones I need to "aim" for usually the outside leading into the turn, the apex cone and the outside leading to the next element.
Goodluck, David J. '89 240sx CO Region STS |
Hey Bbandit, how do you do with the open diff? I still have my open diff and manage to place in the top 3 or 4 usually in novice, but in GS I am usually near the bottom of the field. I just picked up a LSD, but I have to clean it up change the oil and get the pre '95 J30 axels before I can install it. It will be interesting to see how that changes my times. I think with that I will still be able to compete in stock catagories since it is basically the same diff as was an option on our cars (same gearing, different output flanges)
i know i should get into GS but DSP seems to be a lot more competitive since all of the 240s are in the DSP i finished 3rd last autocross with 101.7xx sec 2nd position ran 101.3xx 1st place ran 100.xxx <-- with slicks and tein HEs hopefully, i'll do a lot better next autoX :) |
| All times are GMT -6. The time now is 10:29 AM. |
