-   -   Wheel bearing problem (#/f/showthread.php?t=325723)
rnkelly 06-03-2010 05:20 PM
Hey guys,
Have a s14 se, front wheel bearing blown so took it apart and tried to replace it. Turns out I have non-oem spindle/hub assembly- it's 34mm spindle nut size (bought the car with upgraded z32 brakes, thought they were z32 anyway).
I guess when the brakes were swapped the guy I bought it from just swapped everything out including the spindle, the dust cover didn't have to be modified either.
So now since the hub/wheel bearing is unserviceable I think I need to swap out the spindle back to s14 then get a new hub assembly.
Does anyone know what car this spindle/hub/brake assembly is from so that I can just get the hub assembly?
It 34mm so I'm thinking non usdm or Infiniti? j30? cefiro? I don't see any markings on the parts to cross-reference.
Thanks.
,Ryan
