-   Engine Tech (#/f/forumdisplay.php?f=96)
-   -   RB25NEO Randomly Not Starting (#/f/showthread.php?t=651592)
Mofuhcka 10-06-2017 09:47 PM
I am completely lost at this point. I have an R32 sedan with RB25NEO tuned on a Power Fc. Starter was starting to go bad so I swapped it out for a brand new one. Went to start up and it would just crank but wouldnt turn over. Eventually used starter fluid and it worked, so I could drive back home. Drove back perfect, full boost and everything. No problems. Figured it was fuel related so I changed my fuel filter and made sure the injectors were clicking. Good to go. Tried to start and did the same thing, would just crank. Now I am thinking it was a spark issue. Next day I decided to make sure my battery wasnt starting to go out. Put a battery from my wifes car on and same thing, just cranks. My battery even started my wifes car so ruled out the battery. Go to swap my spark plugs and upon taking the cover off, I noticed some water due to my vented hood. Siphoned all the water out and let the rest dry up before pulling the spark plugs. Put new plugs in and still just cranks. So I figured the water messed with the coil pack. Put in my spares and still just cranks. Checked if I have spark and it seems intermittent. Added extra grounds and still nothing. Check CAS and it was spinning really free so also swapped that out with a spare. Still just cranks. I dont know where to go from here, so any suggestions would be GREATLY appreciated.
