-   -   Car value (#/f/showthread.php?t=627485)
Mrogers27 04-12-2016 10:34 AM
Car value
Just wanted to post my car and get some input on a price range I should sell at.
https://spacecoast.craigslist.org/cto/5526866315.html
Tucker240 04-12-2016 01:23 PM
--Deleted--
S14kouki805 04-12-2016 01:35 PM
1 Attachment(s)
Attachment 92362
:picardfp:
ZenkiKid 04-12-2016 02:32 PM
Space Coast??
http://images.mentalfloss.com/sites/...aceghost_0.jpg
Mrogers27 04-12-2016 02:33 PM
I try to copy and paste the parts list but it says "moderator needs to approve". I tried to do it on Craigslist and they flag the posting and delete it.
Mrogers27 04-12-2016 02:37 PM
s15 sr
kouki ecu and wire harness coil packs ect
S15 oem injectors
New s14 valve covertomei proncams
tomei coil pack cover
tomei fpr with matching gauge
nismo motor mounts
tomei style oil pan
circuit sports rocker arm stoppers
all new gaskets
custom shaved and polished intake manifold
tomei oil cap
aeromotive fuel pump
era 72mm black tb
aem air filter
polished charge pipe
cx racing ic kit
tial bov black
New vtc gear
tomei 7960 turbo kit
circuit sports oval d/p (moonpie style)
stance water neck spacer
black coated water necks and turbo elbow
touge factory valve cover nuts
kazama oil catch can
nissan oem fan shroud
cx racing radiator
isis rad hoses
isis power steering line
power steering
6 speed s15 transmission
nismo lightweight flywheel
braided clutch line
exedy stage 2 clutch
dss 1pc drive shaft
s15 rear diff welded
cody ace a/c brackets
compressor lines and drier evaportor new o rings
all lines near turbo have been wrapped with defi heat sleeve or gold heat tape including a/c lines
18x9 cosmis rims w/new tires
carbon24 04-12-2016 02:38 PM
Originally Posted by S14kouki805 (Post 6048201)
Attachment 92362
:picardfp:
:snoop::snoop::snoop:
Mrogers27 04-12-2016 02:47 PM
S15 sr
Kouki ecu and wire harness coil packs etc
Oem s15 injectors
New valve cover
New vtc gear
Tomei 7960 turbo kit
Stance water neck spacer
Tomei poncams
Tomei coil pack cover
Tomei fpr
Tomei fp gauge
Nismo motor mounts
Tomei style oil pan
Circuit sports rocker arm stoppers
Shaved polished intake manifold
Era1 72mm Tb
Aem air filter
Polished charge pipe
Cx racing ic kit
Tial bov black
Touge factory vc nuts
Kazama oil catch can
Nissan oem fan shroud
Cx racing radiator
Isis rad hoses
Isis ss braided power steering line
6 speed s15 trans
Nismo lightweight flywheel
Braided clutch line
Exedy stage 2 clutch
Dss one piece driveshaft
S15 welded diff
Cody ace ac bracket
Mrogers27 04-12-2016 02:51 PM
Z32 front and rear calipers
Z32 ebrake and cables
Z32 master cylinder
Drilled and slotted front rotors
Braided lines new ac delco rear rotors
Brake master heat plate
Ksport pro coilovers
Braced and boxed power brace
Pbm tension rods
Rear toe and ruca
Modded rear subframe
Pbm pro knuckles
Energy suspension rack bushings
Mrogers27 04-12-2016 03:01 PM
New black carpet
Clean dash. One crack has developed over steering wheel
Nardi steering wheel
Boss hub
Led cluster lights
Greddy shift knob
Led dome light
Buddy club drivers seat
Nasgia rails
S14 passenger seat
Pro sport boost and water temp halo gauges
Hks gauge holder
Aem wide band
Viper alarm w/keyless entry(not installed,bnib)
Jvc head unit
Polk audio speakers
Type x skirts,
Type x wing
Type x Front bumper
Type x tails and lower trim
Fpr rear valences and front lip
Clear square and fender lights
East bear mirrors
Clear headlight housing
Hids
rawgarage 04-12-2016 03:22 PM
sheeeeesh...
Kingtal0n 04-12-2016 07:23 PM
At this stage there are so many built koukis for 9k I would say you need to start below that. Consider parting it out. You might be able to get 5k just for the car with a stock engine. For some reason, its the car people are after, and the mods just seem to "go with it" nobody wants to pay for mods anymore.
