-   -   93 240sx S13 Hesitates when accelerating on low rev (#/f/showthread.php?t=456693)
marryson 05-30-2012 09:44 PM
I have posted this before but i thought I fixed the problem..... so here i am again. my car would hesitate (Rock back and forth) when accelerating below 2000rpm. This started happening when my coolants were leaking and I was driving for 10-20 minutes without even knowing about it. when I got home, there was light smoke coming out of the engine somewhere. when I fix the leak and replace my coolant, everything is fine except for the hesitation issue. I changed my spark plug but that didnt help. any ideas ??
drifter1992 08-13-2012 08:16 PM
my buddy had a hestitation, he changed his plug wires and it helped but still had a bit of hesitation and then changed his igntion wire from the distributor to the igntion coil and it went away, so maybe try that
marryson 08-13-2012 08:28 PM
thank you very much for replying to this old post, I will give it a try thx
S13-1UZ 08-13-2012 08:49 PM
Check the egr or egr backpressure valve with a vacuum tester. It caused hesitation on my KA S13.
RV_S13 08-23-2012 10:13 AM
Plugs, wires, check your timing. It's supposed to be 18-22* btdc. Mine was set at 25. It idled smooth but hesitated like a mofo. Once I set it back down I gained a ton of torque back.
