S14 shakes after z32 upgreade
Hey guys,
Couple weeks ago I bought some 30mm z32 front brakes from a member on here and installed them on my car along with the provided used rotors/pads. Bled the brakes and they work fine but now my steering wheel shakes past 50ish-mph. It is not terrible but its definitely noticeable. One of my favorite attributes of the car when bought completely stock was it's dead still steering wheel cruising at 80mph. First thought warped rotors but I'm pretty sure that causes brake pedal surging during decel which I get none of. Maybe it could be the new rotors are a lot heavier than the dinky stockers and just cause vibration? Thoughts? Thanks |
Warped Rotors? Loose lower control arm bolt? Bad wheel bearing? Loose lug nuts? All things to check
Rotor balance or run out of the fitted components. Cannot be warped rotors as that will only surface once brake pressure is applied.
im having the same issue, pretty sure my drilled/slotted rotors got warped, bought them used after all. getting some brembo blanks soon
thanks |
Bet wheels are loose
You may also have noticed that there are metal wire inserts around the circumference of the disc or rotors. This is a factory or manufacture balancing of the rotor or disc due to casting thickness variances. Hope this helps. Oh, and never try locating the disc or rotor using the wheel bolts or studs. The celarances are just way too large for any success here..:2f2f: |
| All times are GMT -6. The time now is 08:23 PM. |
