clutch sensor not engaged
92 hatch. On that bar attached to the clutch pedal, there is a hole in it. It looks like it should have a rubber bumper there to engage a switch behind the clutch pedal. Am I right in my assumption? Im referring to the two switches located forward and aft of the clutch pedal. The upper aft switch has a bumper that engages it on the clutch pedal. Sorry if this is stupid, im new to nissans. I've attached a picture to illustrate the issue. Yes I know the clutch master is leaking, haha
http://i1190.photobucket.com/albums/...ket_14169_.jpg |
Yes, you need something there that will push in that switch when the pedal is pushed in.
Thanks I figured it out now
| All times are GMT -6. The time now is 09:53 PM. |
