-   Z Chassis (#/f/forumdisplay.php?f=98)
-   -   350z and frontier clutch the same? help... (#/f/showthread.php?t=289183)
wow-thats-a-cool-car 11-10-2009 02:46 PM
Ok I have a 2008 nissan frontier with a vq40de in it. I need to change the clutch in my truck and im not really finding any options other than OEM. Is the 350z and frontier transmission's the same? Can I use an upgraded 350z clutch in my truck?
There has to be a nissan tech out there that can help.
-thanks in advance
lazysk8er2 11-10-2009 02:49 PM
best bet is to look up part numbers try courtesy nissans website
wow-thats-a-cool-car 11-10-2009 02:56 PM
thanks for that!!
im pretty sure its the same...the numbers were the same
does anyone have anything else to add?
shinobis13hb 12-06-2009 04:15 PM
check the diamiter of the disk and all that stuff aswell just do some reserch. im pretty sure they are the same trans... try wiki
ZSpeedPerformance 02-02-2010 09:08 PM
Not the same, The 4.0 uses a 260mm clutch set up and the Z33 uses a 240 and 250mm depending on year.
I looked into the 4.0 clutch, ordered to look at it and it is totally different. Huge pressure plate, Very small/narrow disk facings but is in 260mm form.
