s14 doors on s13
I have done a bit of study and was wandering if s14 doors fit a s13.
Thinking of doing a s13.4 but all ive ever seen have been front clip swaps, so I thought id ask?? |
I believe you have to do metal work and match up the fenders from the s13 and s14 im 99 percent sure the s14 doors are differnt
Is this a serious question? People dont swap "clips", they just swap bumpers, hoods, lights and radiator support. You cant even use OEM fenders because they dont fit (S14s are alot larger body than S13s). So what makes you think the door would fit...
is this real life?
Actually it was a highly intoxicated question. I know s14 are an inch or two wider on the subframe and the fenders are shaped different.
Since I waz lazy, intoxicated, and this was zilvia; what better place for such a controversial question... If the entire front outer skin and radiator support are not considered a clip then idk. Different generations, cultures... appreciate the responses |
Sorry guy, but too funny! |
come on guys, you forgot the classic response...
"with enough time and money, you can do anything." |
| All times are GMT -6. The time now is 10:54 AM. |
