s13 wont shut off
so my car randomly died on the way home today...i found that it was a popped ecm? 25a fuse...i switched it with the one that was right next to it to get my car home...replaced the fuse and now my car still wont shut off unless i kill it and pull the fuse...any ideas?...im stumped
really? no one knows?
Check all of your grounds. Just had this issue yesterday. Everything turned on- would not turn off. Turned out to be a couple small ground wires on my main harness that I had not yet hooked up.
probably a relay stuck closed Check the ECCS ones under the hood
replaced relays, checked every fuse, grounds all seem to be in order...my harness is kind of a hack and i have recently replaced the throttle body. i noticed that my stereo started acting up after that and later that day is when it popped the fuse. is there any wires that run around the throttle body that could be a cause to a problem like this? it seems like it is a short of some sort
Still a problem...anyone have any ideas? Could it be a bad ignition switch if it still turns off accessories? ...im about to just run a toggle switch to the fuse because pulling the fuse every time I have to shut the car off is annoying and slightly embarrassing
| All times are GMT -6. The time now is 05:14 PM. |
