Spray bomb Paint job and wet sanding and buffing
Okay guys this is me proving that you can get a awsome paint job for under 200 dollars. If there is already a thread up about it im sorry for posting this. I have just sanded down to stock primer on my car used a good new primer and sanded with 180 grit then 220. Laid only 2 coats of Krylon indoor outdoor gloss black. Now these pics are only after sanding with 400 grit and buffing. Now I know primer is coming threw that only because this was a test and i only did 2 coats. I will lay more coats of black. I only sanded and buffed a small spot for a test. Below the body line is unsanded just how it came out the can paint. Im stilling going to lay more coats and go 800, 1000, 1500 then clear it and wet sand all the clear more pics to come tomorrow. http://i42.photobucket.com/albums/e3...8/HPIM0791.jpg
http://i42.photobucket.com/albums/e3...8/HPIM0792.jpg http://i42.photobucket.com/albums/e3...8/HPIM0793.jpg http://i42.photobucket.com/albums/e3...8/HPIM0794.jpg http://i42.photobucket.com/albums/e3...8/HPIM0795.jpghttp://i42.photobucket.com/albums/e3...8/HPIM0796.jpg http://i42.photobucket.com/albums/e3...8/HPIM0797.jpghttp://i42.photobucket.com/albums/e3...8/HPIM0799.jpg |
| All times are GMT -6. The time now is 01:48 AM. |
