300ZX Z32 Aluminum Calipers / 5 lug hubs / Q45 Diff Conv. Axle
UPDATED 1/20/2020
All parts were working when removed but as is. No trades needed, Thanks for looking! 300ZX Emergency Brake Conversion If you are running rear z32 calipers brakes you need this. Bolt on for S13/S14, converts to Z32 drum emergency brake. I’ve installed 10+ sets if you need any install info lmk. Includes all hardware and anchor bolts, springs, nuts, etc. Pads have good meat on them, comes with 3ft of cut cable for splice method found here: http://importnut.net/300zxbrakeswap-ebrake.htm 300ZX Ebrake Conversion with cut cables - $185 https://live.staticflickr.com/7844/3...fbc87afd_c.jpg https://live.staticflickr.com/7848/3...b9b584e7_c.jpg 300ZX NA Rear 5 Lug Hubs S13/S14 Bolt on rear 5 Lug, No play on bearings. Ready to use. Came off driving car. Non-tabbed $110[/B] https://live.staticflickr.com/65535/...37e78b38_c.jpg https://live.staticflickr.com/65535/...146176c4_c.jpg |
I just Pm’d you
More Ebrake sets available!
Calipers, Hubs, and Ebrake ready to ship!
Got a z32 master cylinder?
Sent from my SAMSUNG-SM-G920A using Tapatalk |
pm sent. thanks
Calipers, 5 lug and Ebrake still available!
300ZX Calipers, 5 Lug, and Twin Turbo Axle still available!
Ebrake sets sold out for now. |
Best offer for TT Axle! Shipping available!
I heard somewhere that j30 axles worked as well for the q45 diff in a s13 is that true
The Q45 uses the larger R230, the ring gear and casing is bigger and uses larger diameter axles. So to put it into a s chassis you need a Z32 TT drivers axle and a Q45 drivers axle. Also the larger Q45/TT hubs need to be used. Hope this helps. |
Caliper, 5 Lug, and TT Axle still available!
300zx rear conversion
i sent you a PM :)
Rear calipers still available? Where you located? PM me?
Just Hubs and Axle still available!
Do you expect to have E-brake assemblies back in stock soon?
300zx Axle
Hey hows it going, is your axle for the 300zx still available ?
Updated 1/10/2019!
More Ebrake sets and Hubs available! |
Sent you pm....
Just have a few more Ebrake sets, hubs and axle also still available
Shipping available!
One Ebrake set left!
Hubs and axle also available. |
5 Lug Hubs and Axle still available! |
Still got Hubs!
Updated 4/16/2019!!
What’s the difference between tabbed and non tabbed? Looking for a cheap 5 lug swap for my s13
| All times are GMT -6. The time now is 04:55 PM. |
