-   USA (#/f/forumdisplay.php?f=25)
-   -   Wheel stud question (#/f/showthread.php?t=430196)
Bullitt_180sx 01-16-2012 06:33 PM
Wheel stud question
Is there another Nissan model or any other car for that matter that has a longer stud than a stock s13 but will still fit into the stock hub. I have to run an 8mm slip on spacer for my wheels but need longer studs, don't really want to fork out the dough for nismos or anything right now.
joeapple8 01-16-2012 07:01 PM
Don't be a cheap ass.
Circuit Sports 60mm Extended Wheel Studs S13 S14 240SX
Bullitt_180sx 01-16-2012 07:35 PM
I guess I wasn't clear enough in my question, but thank you for trying....
ryandriftingfat 01-17-2012 11:41 AM
If that's the price for one, they are half of that price at Phase2:
Circuit Sports 60mm Long Wheel Studs : All New Carbon Steel
huffandpuff00 01-22-2012 02:19 AM
you can find longer Dorman studs...they are around 1/4" longer
rob22 01-22-2012 02:36 AM
im using 5mm slip on spacers on my stock studs.
i want to use 8mm slip ons as well so ill be going with the nissan quest wheel studs.
there 46mm long compared to our stock 42mm.
Bullitt_180sx 01-22-2012 07:24 PM
^I've heard people say that, but I've never gotten a clear answer on what model year matches up, so I went on autozone.com and checked a few model years and quest studs are 12.90mm as opposed to s13 at 12.83mm on the knurl diameter.
TheRealSy90 01-22-2012 08:28 PM
Man the circuit sports studs are cheap as hell already...
sliverrr 08-13-2012 12:57 AM
hey there guys.. I need help. I had 5mm spacer on stock wheel stud and I need an extended one ASAP! problem is I don't know the knurl diameter and length. Can anyone tell me what is it and what brands out there do you recommend? My car is a 96 Nissan Silvia K's S14 JDM. Its a 5x114.3, 1.25mm... I went to a shop to get an ARP wheel studs but the guy told me that the JDM S14 wheel studs might be different from the USDM. what do you guys think?
thanks!
dawagarage 08-14-2012 02:18 PM
#/f/tech-talk/392146...-s13-rear.html
rotarystar 12-27-2012 05:51 PM
Just buy extended studs, they're not expensive.
