my dream ca18det drift coupe 2 years building
First off my name is nick ive ben building race cars and doing fabrication on my own car along with driving them for quiet sometime now
ewingtech is my instagrahm if youd like to see my work and more pics of my car ... this is a build for myself ive ben working on slowly as ( money and my life letts me) i decided to build my dream silvia my dream not anyone else this car is built for the track ! this car is me and has ben my life for sometime and its just now about to come to an end ill be posting pics i have some pics of before and after because of time i have lost lots of pics of the work but you can see for yourself engine bay Before http://i1077.photobucket.com/albums/...psyjlf8shi.jpg After http://i1077.photobucket.com/albums/...psyrsqtmec.jpg car specs s13 coupe purchased hear on zilvia oh maybe 4 years ago... All the work seen on this build has ben done by myself or a fellow pro body stuff silvia front instant gentalmans kit original stuff when purchased suspension d2 drift spec coilovers all partshopmax suspension knuckles rack spacers tie rods lca shortend sway bar you name it its got it all set up by my freinds at parts shop max (thanks guys!) thanks martinspec! z32 brakes cnc dual brake master cylinder parts shop max hydro ebrake stainless braided lines custom made fill necks tomei 2way lsd stock axles engine is a (fully built) ca18det now a ca20det ca20 crank ca18det block bored to 86mm aeiries 86mm pistons acl race bearings cometic pro gasket kit with teflon coatings nismo oil pump balanced bottom end probably forgetting things ported single port ca18det head tomei 256 poncams supertech dual valvesprings and titanium retainers clean lifters fresh head oversized rb25 valves machined for ca18det tomei cam gears new nismo water pump power enterprise timing belt ewingtech custom made ross machine racing intake manifold single port oval velocity stacks ross machine racing 90mm throttle body bosch 1600cc injectors bosh 044 pump from fuel cell to a 1 gallon serge tank bosh o44 feed pump to engine ls3 coilpacks synapse engineering map sensor and boost and oil pressure sensors all wired in to aem v2 gtx3576 turbo synapse 50mm wastegate synapse engineering radial bov partshop max radiator should be around 550 600 hp als system in the workx transmission z32 rebuilt and adapted to ca18det via cut and shut method spec stage 5 clutch unknown lightweight chromoly flwheel every line on the car is a earls or summit brand an line ! custom made fronttube and rear half formula drift spec cage with added stuff entire center section of car has ben cut out frame was made part of the roll cage and seats mount to the frame custom made aluminum floor and trans tunnle full car is custom wired mill spec and breakers no fuses fire proof reychem to much to list the things ive done i will continue editing post and updateing hear are some pics still an ongoing project inside shot http://i1077.photobucket.com/albums/...psduti3puy.jpg intake manifold unfinished ill take some more recent ones http://i1077.photobucket.com/albums/...pspfgam7wj.jpg http://i1077.photobucket.com/albums/...psiimxzwf3.jpg made the fuel rail http://i1077.photobucket.com/albums/...psaq8zaqus.jpg breaker and switch panle http://i1077.photobucket.com/albums/...psesjgms2d.jpg http://i1077.photobucket.com/albums/...pslouenctj.jpg http://i1077.photobucket.com/albums/...psk8cdsbzc.jpg me welding my 4in intake http://i1077.photobucket.com/albums/...psddenucvv.jpg http://i1077.photobucket.com/albums/...psjjqm1pus.jpg powder coating goods http://i1077.photobucket.com/albums/...psefgsjsau.jpg older pic of some moc up http://i1077.photobucket.com/albums/...pstnsr6ifd.jpg out with the welded in with tomei 2way! http://i1077.photobucket.com/albums/...psnlyzajnc.jpg older front shot you can see engine bat is different not sorted out yet http://i1077.photobucket.com/albums/...psmqgyfsul.jpg http://i1077.photobucket.com/albums/...psln5dh9pc.jpg http://i1077.photobucket.com/albums/...psipjt0nxs.jpghttp://i1077.photobucket.com/albums/...psemx4zslr.jpg http://i1077.photobucket.com/albums/...psk6kjjrtk.jpg more recent inside shot http://i1077.photobucket.com/albums/...psl3cl6bxr.jpg http://i1077.photobucket.com/albums/...psw3v2zlp8.jpg http://i1077.photobucket.com/albums/...psnuia6lyy.jpg thats all for tonight ill post up more pics and info ! |
| All times are GMT -6. The time now is 10:20 PM. |
