Help? Jdm half amber half clean turn signals
Does anyone know if its plug and play with a ISSN harness or do I have to rewire it?
Sent from my HTC_Amaze_4G using Tapatalk |
Usdm*
Plug and play
I just bought some and the signal bulbs don't work but the dtrl works, I got all new bulbs
Looks like you may have a issue somewhere else then.when I bought my it worked fine.
from what ive seen with these is the drl on wen lights are turned on and amber only comes on wen you hit blinker. thats the way factory wirred them . if you want both lights on you need modify harness by using chuki dual filament bulb connector
| All times are GMT -6. The time now is 02:01 AM. |
