No power going to fuel pump
Recently did a auto to 5spd swap and the motor was running great @ 180psi all 4 cylinders until a couple of days ago I went to start the motor and the fuel pump didn't prime and isn't feeding fuel to the motor. A couple days later I go to turn on the motor I went and I replaced some fuses and the starter primed. Then today I went to start the motor again and nothing. I gave direct power to the fuel pump and it works fine so a bad fuel pump isn't the case. Checked the fuse for the fuel pump as well and replaced it, still not the case.
When I put it in ignition mode all power goes to everything but the fuel pump Could it be a faulty relay, ECU issue, or a ground somewhere? |
check the ground wires that bolt to the head. there are 2 as I recall (but could be one not checking 2night), one come outa the injector wire harness near the firewall (and bolts to rear exhaust side corner of head. other near upper timing cover front near coolant neck(not the one by the throttle body to battery). if loose or not making good contact u"ll have your exact issue. lmk (info provided is for DOHC ka24de s13) may be different for SOHC and s14 but similar
The ECU controls the fuel pump relay (green wire if i remember correctly). If the engine runs when the pump is wired directly, chances are it is a relay or a wiring problem.
Anyway, if you get blown fuses problems, you might want to investigate them ... there is a known problem with aftermarket fuel pumps on S13/14 chassis, the wires from the relay to the pump are too thin and need replacing. You can easily check this with a voltmeter, when it happens voltage at the pump is lower than voltage at battery (like 10V or less instead of 14) edit : it reminds me of another known "electrical" problem : lowered S and Z chassis tend to munch through the electrical harness that pass just up the front tyres (unless you relocate it). Worth checking too ... |
Theres a relay associated with the fuel pump, as well as the ECCS relay that also must be working to feed power to the pump properly. Break out the multimeter and check the wires where the pump is hooked up.
Sometimes this can happen due to poor seating of the F3 plug. Make sure it is latched in properly. Its possible to have proper power to nearly everything, exept if that plug isnt seated nearly perfectly it wont send power to the fuel pump. Thats the big plug located by the ECU, its white with a black cap. Google F3 plug if youre not familliar, itll come up. |
Can't find f3 plug, I disconnected the ECU and reconnected it and nothing happened
And the relays are working properly
checked the plug ad its on right, any other tips?
If youre sure the relays are working properly it may be time to take out the multimeter. Start at the pump and make your way up the harness. Possibly consider running new wires for it?
| All times are GMT -6. The time now is 02:35 AM. |
