Gauge cluster not working
I recently purchased a 1995 240sx, the previous owner swapped a sr20de into it. The speedometer, temp & fuel gauge does not work. I thought the cluster was just fried, so I bought another one and it is still the exact same. Not sure what it could be. Any help would be greatly appreciated.
Did you try searching? Like on google? 9/10 times google has the answers man
You need to download the fsm for your car and ceck wiring. Check your f4 plug...thats where the wiring passes thru from engine to chassis, regarding speedo,rpm, coolant temp, fuel... Welcome to zilvia, NO ONE WILL SPOON FEED U HERE |
| All times are GMT -6. The time now is 03:56 AM. |
