-   -   SR S13 Upper Engine harness problems (#/f/showthread.php?t=188379)
blacklable245 04-20-2008 03:08 PM
OK so a few weeks ago i went to start up my car. When it FINALLY started it sounded like a WRX, which at that point i thought a coil pack had gone bad, so i popped the hood and changed out packs with some extra ones that i had. Started back up, still sounded like a WRX. So i started to unclip the injector harnesses, check first and second with a noid light, and both fired fine, got to the third, and no signal. I check all my ground, switched the ECU with one that i knew was good. Still nothing. Im stumped, i have checked the injector it self and its good. Has someone had this problem before? :confused: HELP!!!
nicku 04-20-2008 09:32 PM
well...have you checked with the multi-meter?
blacklable245 04-21-2008 08:30 PM
yep, found a break in the wire somewhere in the harness. got it all under control
vanguard 04-22-2008 03:43 PM
where was the break located by? hope that doesn't happen to myself sometime thats why
