rear tie rod replacement
hey everyone,
I have a 1992 180sx (hicas model) and I found out yesterday to have a knocking noise in the back which I discovered to be a failing tie rod. I have been searching google and frsport for replacement parts. Only part I found is a SPL hicas delete with the tie rods included but this is not what I am looking for. Am I just using the wrong term in: rear tie rod? Thanks for your help folks.. |
Thanks for the link but it still does not solve my problem as I am in need of the name of the whole assembly rather than the original part number
Envoyé de mon iPhone Ã* l'aide de Tapatalk |
What part of the Hicas steering rack do you need? The inner portion or the outer portion of the tie rod assembly?
Just put your little mouse pointer over the part number that goes with the part or parts you need and the name will be given to you. Assuming you have java script enabled. |
I need the inner portion, i do not have java enabled on my phone, i will take a look tonight when i come home. But still, I would have prefered to replace the whole thing with an aftermarket part rather than replace only the inner portion. Btw, thanks for your time
| All times are GMT -6. The time now is 03:11 AM. |
