back at it again!!!! jdm dash harness chasing
so I'm chasing wires while I wait for a friend to get a full chassis jdm harness for me. all gauges are getting power but none work? crazy I know an s13 with an analog cluster that doesn't work :spank:... well just curious I;m going to post some stuff of how to test but curious on how to test continuity.. do I haveto connect a wire to the end at the ecu? then test the wire at the cluster?
ok so the I believe was red with yellow stripe had constant power on plug1 (temp) where the clock keeps its power... gauges are getting power to get ambers to turn on with turn of headlight switch.. the other yellow stripe wires o the other are getting connection when in on pos but yet gauges aren't working tested another cluster and same thing weird is that is was working fine then stopped.. this is stock jdm sr20det cluster, my car is right hand drive |
Converted ? Have you used the fsm to figure out which is what and so on?
yeah conversion, yeah I got the fsm I can see the signal and power ground wires...
here is what I found about testing them.. not sure how to do continuity on a wire tho just on fuses and such |
crap I can't copy it but tells me to jump the wire to ground for th gauges to see if they move and such...
but how do you test continuity between battery term and wire? do I have to hook a wire to neg on battery then test the wire that should have power or what? im new to wiring so any help would be greatly appreciated.
LOL, just to chime in buddy.
Your full body RHD tip to tail plus cluster is in the mail!!! Just thought I would add to your thread!! HAHA |
hahah thanks! bro.. can't wait to get it in my car and get that car driving..
Yeah I bet.
Your really gonna F**k them up going through toll booths. lol |
| All times are GMT -6. The time now is 05:11 PM. |
