-   -   S14 Power FC (#/f/showthread.php?t=677412)
Loomis112 09-01-2020 08:25 PM
S14 Power FC
I have a 95 S14 with a redtop SR20.
I'm a little overwhelmed and need to be pointed in the right direction.
I bought an apexi power fc from a user here and plugged it in. No start no fuel pump prime and no display on the hand held.
I started to look into it and from what I can read the Power FC uses all ECU power and even requires backup power to run.
I took a multimeter to my wiring harness and this is what I found.
Pins: 38 B/W and 47 B/W have no power and pin 46 R is getting 12v
So the backup power is the only power that seems to be coming into the ECU
Pins 38/47 are both ECU powers and it looks like one of them dissapears into the harness and one runs to the ECCS or some other relay that is close to the ECU plug?
I was fighting back and forth wondering if this was a ka harness or sr harness because a lot of pins/wires have been removed from the plug nothing too important it seems but still.
I could use some help overall.
my main question is im supposed to have 12v at pins 38 and 47 correct? and if so where do I start troubleshooting?
forgot to mention ECU serial #A11000G90 runs the car its drive-able but extremely rich
Loomis112 09-01-2020 10:30 PM
I think I?ve narrowed it down to it being the ECCS relay I tried searching a part number for it but can?t seem to find the right one.
Does anyone know where to get those relays?
samotage 09-02-2020 02:35 AM
Pull the relay, it will have numbers etc on it and use those to find an equivalent [emoji6]
Sent from my iPad using Tapatalk
Loomis112 09-02-2020 07:17 AM
Sorry forgot to mention that number ST-01040 but nothing that comes up looks like it on the web.
zombiewolf513 09-02-2020 08:20 AM
https://www.ebay.com/sch/i.html?_fro...w=nissan+relay
Loomis112 09-02-2020 08:28 AM
Originally Posted by zombiewolf513 (Post 6393479)
Thanks man ordered the RE-RY51 Gonna try that out I appreciate it.
S14rebuild 09-02-2020 10:50 AM
Before u order it, did u test the pins? No sense in just swapn parts out..
Loomis112 09-02-2020 12:33 PM
The ECCS pins? If so yes with the key turned it showed no voltage
S14rebuild 09-02-2020 01:00 PM
Where the eccs relay plugs in, there are pins, u should be checking for grounds and voltage via the fsm, before u condone the relay as bad and replace it
Loomis112 09-02-2020 01:36 PM
I will do that tonight luckily the relay was cheap.
Loomis112 09-02-2020 07:57 PM
Just for the sake of ending the thread it was indeed the relay.
zombiewolf513 09-02-2020 08:44 PM
You get the FC working???
Loomis112 09-03-2020 10:32 AM
Yes I did it was the ECCS relay and a loose wire
S14rebuild 09-03-2020 10:37 AM
Nice!!!!!!!
zombiewolf513 09-03-2020 11:16 AM
Ok, good! I hope it serves you well!
