Which transmission fluid?
I have a 93 KA and was wondering which kind of tranny fluid I should get for my new tranny. I have narrowed it down to Red Line MT90 75W-90 GL-4 and Amsoil full synthetic 75W-90 GL-4. I currently have the Amsoil in my tranny but it was already fucked up when I put it in so it therefore has never shifted smoothly and I don't know if it really is good or not. I have heard many great things about Red Line MT90 and the Shockproof Heavy fluid also. Which do you guys think would be better?
Red Line MT90, I would only use shockproof if your tranny is totally fubar.
Fubar? Sorry if I am a noob.
http://www.rzm.com/pvt.ryan/main/pvtposter.gif |
hopefully his next question isnt... Whats that? or what movie's that? |
1 bottle of Redline Shockproof Light, 1.5 bottles of Redline MT90.
GM Syncromesh
i use the pennzoil syncromesh and works flawless and cured my grindings completely... seems to hold up fine for the last 6 months or so.
that movie is Saving Private Ryan awesome movie IMO i've been hearing a lot of great things about GM syncromesh, i have a lot of access to synthetic gl4 as well as gm syncromesh i'm going to try it myself and put my transmission on the line what do you guys think should be the variables? obviously the first test would be Full Synthetic test 2 would probably bea mixture of 1/3 Syn and 2/3 Gm syncromesh test 3 would probably be a mixture of 2/3 syn 1/3 GM syncromesh test 4 would be 100% GM syncromesh, IIRC GM Syncromesh is rated as 75w85 GL4 let me know what you guys think |
It's for transmissions that are designed to use Motor Oil. Not Transmissions that are designed to use Gear Oil. |
i have a simular issue well not really when i drove the car before i pulled the motor she shifted fine now its super stiff its the same stiffness form top of first to bottom of 2nd block idk its weird some one said it could be my short shifter?
syncromesh for the win.i have used if for over 5 years in 2 trannies.cures simple grinds.trust me -you will be happy
| All times are GMT -6. The time now is 04:32 AM. |
