-   South Western States (#/f/forumdisplay.php?f=40)
-   -   built NA sohc start up (#/f/showthread.php?t=411553)
zack hei 10-03-2011 07:39 AM
hey whats up everyone iv got some issues im trying to address about atart up iv recently finished my sohc build got it dropped in the car wired everything up all the lights work properly minus the flip-ups and the starter itself it makes a clicking noise when i try to start it kinda seems like it may be a bad ground or a bad starter, im ruling out the bad starter theory thou due to the fact its brand spankin new anyway heres my question does anyone know if the switch on the clutch needs to be engauged (hence clutch pushed in) in order to start or should it start without so long as its in neutral? and also should the flip up lights work properly without the flip up button on the dash or is that button mandatory?
chetos13 10-03-2011 03:09 PM
battery might be bad or dead and yes u need to engauge the clutch
562s13 10-03-2011 03:45 PM
check your battery cables as well. might be loose or corrosion on em...
Gizmo_S13 10-03-2011 07:20 PM
Was it ever a auto? The switch might still be on wrong location. Sounds like the battery though, on S13s the ignition switch tends to mess up so you can look into that.
