-   Suspension (#/f/forumdisplay.php?f=114)
-   -   BC Racing Coilovers PLUS FREE MUTEKI LUG NUTS!!!!!*********************************** (#/f/showthread.php?t=631025)
IMPORTIMAGE 06-14-2016 09:50 AM
http://i209.photobucket.com/albums/b...f?t=1308794533
http://i209.photobucket.com/albums/b...o-Zilvia-2.jpg
CALL 941-257-9618 and mention KRIS to receive special pricing ON ZILVIA!!!!!
FREE LUG NUTS!
http://importimageracing.com/media/c...end_colors.jpg
**Remember with Import Image you make YOUR OWN package deal! The more you buy the even great your discount gets :)**
Click below to order right off our website!
BC racing coilovers!
BC Racing BR series Coilovers!! Free Custom Spring Rates as well!!
http://www.scoobyworld.co.uk/catalog...ries-group.jpg
+ COMBO WITH ANY SPL PRODUCTS!
http://i209.photobucket.com/albums/b...g?t=1341529710
We are the #1 Vendor in the nation for BC Racing coilovers!
http://i209.photobucket.com/albums/b...g?t=1345474357
http://farm3.static.flickr.com/2642/...0161594c_o.jpg
http://img576.imageshack.us/img576/6...9188325100.jpg
Our BR model is perfect for street driving and occasional road course duty. With easily accessible adjustment knobs for fine tuning your compression/rebound and separately adjustable ride height, having a performance coilover system couldn’t be any easier. You choose how low or high you want your vehicle, no preset ride height here, and our patented concave lower locking ring keeps it locked in. All of our systems come with pillowball mounts to provide the most feedback possible from your suspension and to sharpen your steering response. BC’s available front and rear camber plates also allow you to get the perfect alignment setup without compromise. All this while providing a strong, attractive looking coilover system.
- Mono-tube shock design
- 30 levels of damping force adjustment, adjust compression/rebound
- Pillowball mounts and adjustable camber plates included (where applicable)
- Adjustable rear camber plates available
- Separate full length height adjustable
- One year warranty
- Rebuildable
http://i288.photobucket.com/albums/l...0/IMG_2529.jpg
Technical
- Coilovers use 46mm pistons and 53mm shock housings, the enlarged shock cartridges with specially designed pistons and rods provide a wide range of damping force.
- Valves are constructed of special spring steel, which outperforms stainless steels and produces longer valve life. Valve stacks use a patented deflective system to provide more precise control.
- Patented concave lower locking ring, to prevent unseating.
- Springs are made of SAE9254 high strength, durable steel. Compression tested at over 500,000 tires with less than 5% deformation.
- T6061 Aluminum utilized in spring locks and seats for high strength and lightweight.
- Iron lower brackets on MacPherson struts to ensure rigidity.
- Piston rods are constructed of highly polished steel to lengthen oil seal life and prevent leaking.
- High pressure inner rod guide seals ensure a perfect fit for consistent fade resistant damping and long shock life.
- 2 step coating process utilizing nickel and chromium plating to prevent corrosion.
- Newly developed lubricant oil in shock cartridges minimizes aeration and cavitation.
- An additional bearing beneath each pillowball mount provides the smoothest action and prolongs the lifetime of the pillowball itself.
http://farm5.static.flickr.com/4033/...c1858127_o.jpg
BC Racing RAM type (Inverted)!!!
http://www.google.com/url?source=img...KAc9LxWJV-X4Gg
BC Racings inverted RAM model includes all of the great BR features and then takes it a notch higher. By using an inverted coilover system we move the vital damper fluid away from the detrimental heat sources to avoid overheating the fluid and causing damper fatigue under extreme conditions. The inverted setup also handles high-g loads better and is much more durable under stress situations, such as a race track. Another advantage is reducing unsprung weight by moving the heavy parts to the chassis mounting points. This is a great coilover for those looking to attack a race track, hill climb or tarmac rally.
- Inverted Mono-tube shock design
- One year warranty
- Rebuildable
BC Racing ER series!!
http://www.importimageracing.com/med..._er_series.jpg
Our newest and most advanced model yet is the ER series coilover. It features large external reservoirs front and rear, separate rebound and compression adjustment and a twin piston design. The external reservoirs hold much more oil than the conventional coilover, allowing the coilover to operate for a much longer period of time before overheating. The external reservoirs also house the secondary piston, which allows for the fine tuning of compression. This is the perfect coilover system for the person who wants to fine tune there setup using the separate, 30-way, rebound and compression tuning dials.
- External Reservoir Mono-tube shock design
- 30 levels of damping force adjustment, adjusts both compression and rebound separately
- Twin piston design
- One year warranty
- Rebuildable
http://i48.tinypic.com/axfmp.jpg
Disclaimer- Ad specials not valid on website, only valid by calling 239-540-6385 visa/mc or paypal/googlecheckout.com shipped pricing refers to the 48 states. If you send a payment and live in FL and do not add 6% sales tax, your item will not ship. All returns subject to 35% restocking fee so make sure you want the part before you buy it! if received after 7 days, store credit will be given. after 2 weeks, returns will not be accepted. price subject to change due to manufacturer changing prices.
Regards,
[email protected]
AIM: [email protected]
ImportImageRacing | Discount Performance Parts | Subaru, Mitsubishi, Nissan, Mazda Import Image Racing
Shop Line: 941-257-9618
Visa/Mastercard/Discover/Paypal and (amex) Google checkout!
Import Image Racing - Automobiles and Parts - Cape Coral | Facebook
IMPORTIMAGE 06-20-2016 08:50 AM
Monday Bump!
Regards,
[email protected]
Phone#: 941-257-9618
Visa/Mastercard/Discover/Amex and Paypal!
www.facebook.com/officialimportimageracing
We will meet or beat any competitors price!
IMPORTIMAGE 06-21-2016 08:55 AM
Who wants to get some Great parts at the best pricing around? PM today to get what you need!
Regards,
[email protected]
IMPORTIMAGE 06-22-2016 11:19 AM
We will meet or even beat any pricing for the same in stock item from anywhere else! PM today to get what you need!
Regards,
[email protected]
IMPORTIMAGE 06-23-2016 10:15 AM
Thursday Bump!
Regards,
[email protected]
IMPORTIMAGE 06-24-2016 09:53 AM
Pay day Bump! Buy through us and have some of that paycheck left over to make it through the week! Or have a little extra to buy more parts ;)
Regards,
[email protected]
IMPORTIMAGE 06-27-2016 11:22 AM
Monday Bump!
Regards,
[email protected]
IMPORTIMAGE 06-28-2016 11:21 AM
We will meet or beat any competitors prices! PM us today for pricing!
Regards,
[email protected]
IMPORTIMAGE 06-29-2016 12:09 PM
Wednesday Bump!
Regards,
[email protected]
IMPORTIMAGE 07-01-2016 01:00 PM
4th of July weekend Bump! Message me for even better deals!
Regards,
[email protected]
IMPORTIMAGE 07-05-2016 12:40 PM
We hope everyone had a great 3 day weekend! If you are having a hard time on your day back to work, shoot me a PM and I'll get you some great prices to make your day seem less like hell!
Regards,
[email protected]
IMPORTIMAGE 07-07-2016 10:47 AM
Thursday Bump!
Regards,
[email protected]
IMPORTIMAGE 07-08-2016 12:34 PM
Payday Bump!
Regards,
[email protected]
IMPORTIMAGE 07-11-2016 02:23 PM
Monday Bump!
Regards,
[email protected]
IMPORTIMAGE 07-13-2016 10:51 AM
Wednesday Bump!
Regards,
[email protected]
AIM: [email protected]acing.com
IMPORTIMAGE 07-15-2016 10:03 AM
Payday Bump!
Regards,
[email protected]
IMPORTIMAGE 07-19-2016 08:27 AM
Regards,
[email protected]
IMPORTIMAGE 07-20-2016 12:00 PM
Regards,
[email protected]
IMPORTIMAGE 07-21-2016 11:29 AM
Thursday Bump!
Regards,
[email protected]
IMPORTIMAGE 07-25-2016 09:06 AM
Monday Bump!
Regards,
[email protected]
IMPORTIMAGE 07-27-2016 07:45 AM
Wednesday Bump!
Regards,
[email protected]
IMPORTIMAGE 07-28-2016 11:28 AM
Regards,
[email protected]
IMPORTIMAGE 08-01-2016 10:22 AM
Monday Bump!
Regards,
[email protected]
IMPORTIMAGE 08-02-2016 10:19 AM
Regards,
[email protected]
IMPORTIMAGE 08-04-2016 12:24 PM
Thursday Bump!
Regards,
[email protected]
IMPORTIMAGE 08-15-2016 11:14 AM
Monday Bump!
Regards,
[email protected]
IMPORTIMAGE 08-24-2016 01:19 PM
Wednesday Bump!
Regards,
[email protected]
IMPORTIMAGE 08-29-2016 01:10 PM
Monday Bump!
Regards,
[email protected]
IMPORTIMAGE 09-12-2016 11:21 AM
Monday Bump!
Regards,
[email protected]
IMPORTIMAGE 09-22-2016 12:29 PM
Regards,
[email protected]
