5 lug swap
Whats up dudes, quick question for a new s-chassis enthusiast.
i own a 1990 S13 here in japan. My question is, can i remove my stock 4 lug hubs and swap them out with 300zx hubs and calipers? If so what all is required, im pretty sure i have everything i need. Thanks in advanced |
Brake system will bolt up wats needed is the conversion brake lines, rear hubs will also bolt up just fine.
The front's is a diff matter look up some option's here on zilvia or google thiers a couple choices with its up's and down's. |
the front hubs will not be good? and i have the 300zx steel braided brake lines
he front hubs will not be good? and i have the 300zx steel braided brake lineshttp://goo.gl/R6YO3q
| All times are GMT -6. The time now is 03:16 PM. |
