350z aggressive offset vs-xx
My friend is gonna be buying some work vs-xx wheels he needs to confirm this fitment before he orders. He wants an aggressive stance 4" front lip 5" rear lip. The fitment he has planned on using is 20 x 9.5 -21 (r disk) and 20 x 11 +6 (o disk) will this work or is there a better set up for what he is looking for.
Thanks and before you flame we both have searched with no luck. 95sx |
It will fit,easy all day
But if it was me & i was gonna fork out the cash,I would go with a 10/10.5 less negative in front or close to 0et & the 11 in the rear would be 0 et or bring on the -teens/20ish et. with a med stretch and camber to fit. But this all depends on tire size & the look he is going for ,plus im crazy like that..... PS Z33 can thake lots of rim |
Online Wheel & Tyre Fitment calculator. Offset and Tyre Stretch
Use this to compare between oem size and the new size he wants, tires and make sure it works. |
| All times are GMT -6. The time now is 07:50 AM. |
