-   -   180 will not start..NEED HELPPPPP (#/f/showthread.php?t=270543)
driftredmption 08-01-2009 08:08 PM
ok heres the story, i was drifting 2 weeks ago and kept having feul pump problems. The 15A fuse kept blowing everytime i driftin left corners. I found my chasis wires were chewed to shit due to tire rubbing. I raised the car and tried to cover it for a few more runs but not very successful. I got the car running enough to drive back home early 45 min ride. 2 days later i took it out to the car wash. it died inside the was and kept blowing the fuel pump fuse, now worse then before. I rolled the car out and blew about 4 more fuses. I figureded id let it dry and try later. It started 2 hrs later then died 2 miles from my house. I got AAA to tow it back.
A week later i go to start it because i got my new walbro feul pump. Now the car wont even turn over. All lights come on in the car so the battery isnt dead. I installed the new fuel pump and now i hear the pump turn on, but will not turn over. Could the starter be bad? or what else?
-Car is a '93 180sx with a stock sr20 redtop
Sileighty_85 08-01-2009 09:07 PM
did you even repair the broken wires?
you have shorts in the harness and need repair each wire thats rubb through
