42 offset 18 rim is what is reccommended.. sound right to you?
have a 95 base model and looking at some 18x7.5 rims that have 42 offset... is this correct?
for a miata
ok so they will not fit, or is this your way of saying they wont be flush
they will not be flush
you need much lower to be flush |
so any pics of a 18 with 42 offset on a s14? going to buy today unless convinced otherwise
2 people have already told you NO THEY WILL NOT BE FLUSH, you just aren't listening.
Look at the Wheel Whore thread previously posted and see what specs you like. I am running 18x10s +32 in the rear (much wider and lower offset than what you're going to waste your money on) and my rears aren't perfectly flush. I would need to roll my fenders and get a 10mm spacer to make it flush. |
what are u running up front
18x7.5 +42? Yah itll be flush....
on an ACCORD!!! |
why does tirerack say 42 offset for s14
a 7.5" +42mm is going to look like shit. go browse the wheel fitment thread. |
Your car, your money, your decision. |
After all this time of people showing off the correct sizes/offsets, you should know better than to follow anything but that. Search this forum and realize that what you want is at least an 18x9, +20. |
people let him get the wheels, like he said he wants us to convince him. pssssh its ur lame s14 so YOU decide on how u want it to look. and if your avatar is a pic of ur car than i would have to say poor zenki!
....... damn i cant let the poor zenki suffer, go buy some cheap sportmax 006. front: 225/40r18 federals 595 on sportmax 006 8.5x18" +35 ( add a 15 or 20 mm spacer for fitment.) rear: 235/40r18 federals 595 on sportmax 006 9.5x18" +35 ( add a 10 or 15 mm spacer for flushness look) tires: under 400 shipped wheels: under 670 shipped spacers: 100 a pair tuner lugs: 40 shipped actual love for your s14.... priceless!! |
cant i run 25 mm spacers and still be lookin good with 42
#1 no, that fitment (7.5 +17mm) still sucks
#2 even if you did get it flush (with a 50+mm spacer), flush 7.5 wheels look stupid because they are too narrow |
You can run spacers to make it look good. If you found some wheels that you love then get them, you can use spacers to make them sit more flush.
If your gonna spend money on rims, why dont you do it right and buy something that would actually look good on the car without fucking spacers? Spacers are stupid because its another piece on a car that can fucking fail and break. Get the right size and stop fucking around with dumb shit.
PS: I got a feeling you're pretty much assed out because you already bought ubber gay rims with these sizings... |
^ I'm with him...why waste money?! do it right the first time!
7.5 +42 = FAIL!!! simple 240 math
http://img119.imageshack.us/img119/2057/dsc0249sy8.jpg |
:tweak:i stand corrected, i iz sorry.:duh:
but what is the offset? and wheel specs? |
To my knowledge, the largest wheel/tire that you can properly run on an s14 in the rear is a 9.5" width, +38 with a 275/40. This is a 17" setup. For the front, I would run an 8.5" width with a 22-25 offset. This is a PROPER setup meaning the tire AND wheel are in the fender well with just enough clearance for coilovers.
Like above, you might want to check this out. #/f/chat/129865-whee...re-thread.html |
Yea, and here is your boy GSRACERS quote about his car. Try again smart ass. "20 by 11+ 30 with the first pull on 305-25-20's with some camber. I have since pulled the rears an additional 15mm" |
"proper" doesn't mean anything Quote:
work meister s1 18 by 10 +18 18 by 11 +18 275 fronts 305 rears stock fenders and quarters That's what he's runing and been running. Till he threw a widebody on it and coverted it to a kouki not to long ago. Anyhow, the 20's was for fun. He's not my boy, but I do respect the guy. You never said anything about rolling fenders, or stretching them, your exact words are "This is a PROPER setup meaning the tire AND wheel are in the fender well with just enough clearance for coilovers." There are plenty of people on this fourm that run way bigger rims with lower offsets on STOCK BODY cars that go by your standards of being "PROPER". |
| All times are GMT -6. The time now is 05:31 AM. |
