-   -   3sge beams swapped s14 (#/f/showthread.php?t=643969)
Poirier4 03-28-2017 08:26 AM
Hey guys, I swaped a 3sge beams into my s14 in october 2015, ran it until is stopped running, so I thought ecu was fired, turned out to be just a cut crank pos sensor, anyways by the time i had found why it wasn't running I had bought and cut my harness to run the aem ems-4 as I am planning on going turbo in the future, (once all my other projects are done), had it all running and stuff, but the thing is the ems-4 doesn't run dual vvti and was a waste of time and money and I wont be able to tune properly without changing the cam gears,...... but that's ok my other project will get the ems-4
Running oem harness hacked up to put ecu in passenger footwell
https://www.youtube.com/watch?v=mGETEn_FTMs
Running on aem ems-4
https://www.youtube.com/watch?v=4KTtdBXTHqY
Now i needed a new harness which I bought and installed last night, only a few wires need to be hooked up from the stock f3 plug to the ecu box (alternator, some powers and grounds, tach signal etc)
http://i376.photobucket.com/albums/o...438189_n_1.jpg
http://i376.photobucket.com/albums/o...822116_n_1.jpg
Lexus is300 ecu box mounted in the engine bay
http://i376.photobucket.com/albums/o...289675_n_1.jpg
ready to install new engine harness
http://i376.photobucket.com/albums/o...850023_n_1.jpg
New harness installed in stock location
http://i376.photobucket.com/albums/o...716054_n_1.jpg
couple of things I need to button up
Alternator was pretty simple to wire up last time (Middle plug)
S= 12v constant (senses current at battery)
L= Lamp (should I plug to e202 (white/red I had just put switched ignition last time)
IG= Igniton switch
http://wilbo666.pbworks.com/f/201104...lt_Pinouts.png
only wire I got out of these three connectors is the starter wire so I can start my car with the key #awwwwyeh turn key swap bruh lol
E202 Plug ? Can someone confirm?
http://i376.photobucket.com/albums/o...AC356B255E.jpg
http://i376.photobucket.com/albums/o...220E7699F5.jpg
1- yellow - alternator "S" wire
2- green reverse light (Doesn't matter which wire) 3- red vss
4- unused neutral position switch
5- white/red alternator "L" Wire
6- green/white reverse lights (Doesnt Matter which wire)
7- red/yellow vss
8- black unused neutral position switch/5th position switch
anyways.... I'm trying to figure this out as it's a JDM Model Zenki converted Kouki with a beams swap, lol trying to get everything working and have a very simple oem style harness,
I had tried plugging the 202 plug for the alternator and vss reverse lights like time when i got the car to run with the aem but it didn't work, reverse lights didn't work, vss read nothing and alternator wasn't charging lol, anyways any input on that would help.
OH! and if somebody has made their own f3 to wiper amp and wiper plug harness that'd be great!!! as right now I have wipers on 1speed on a switch
jared420sx 03-28-2017 10:56 AM
:confused:Idgi
Loufig 03-28-2017 12:56 PM
Posted for 1 hour and already in the doing it wrong thread lmao!!! I love this forum
Hatemy7 03-28-2017 01:47 PM
hahhahahah I know what you mean lol
