s13 sr20 into s14 intercooler piping
Ive searched and found very little on this, ive swapped an s13 blacktop sr20det into my 95 s14. Before i put the motor in i ordered the ebay cxracing s14 intercooler kit because i wanted the chassis routing to be correct. Now im seeing that the s13 and s14 kits are different. Im working on mounting the intercooler now and am thinking i need to mix and match s13 and s14 intercooler piping. If anyones done this swap let me know what you did for the piping and if the s14 kit will work, looks like its not aligning properly.
I don't think you will have much problems with it, I have the s14 piping on an s13 you just need to route the hoses a bit differently. If anything I'd probably just get the s13 kit
I own a s14 and also have an s13 SR and im using s13 intercooler piping on that. I think the only prob you might have is the cold side since you ordered the s14 kit cause the intake mani is different between the s14 and 13 SR's assuming your using the stock manifold, the hot side should be no prob. if its not to late maybe you can call CXracing and have them get you s13 piping or even talk to them about your problem :)
thanks for the input guys, ill be finishing the install this week and see, if need be i can just pick up an s13 cold pipe somewhere. This projects 2 years in the works, almost done.... and i miss driving my 240!
| All times are GMT -6. The time now is 10:40 AM. |
