-   -   1996 ka24de into 1990 (1996 harness) (#/f/showthread.php?t=523905)
Toplevel4ever 06-19-2013 09:16 PM
EDIT
Forget it. getting 91-93 parts lol
So I just purchased a 1990 240sx with a 1996 ka24de swapped into it but unfinished. It's 1996 everything. Engine, trans, engine harness and ecu. Has anyone done this using the 1996 harness and all?? I need help with what wires I need hooked up to get it running.
All the guy had done was had the engine and trans installed and that'd it. I've had it cracking but no start yet. I hard wires the fuel pump and hard wired the crank sensor because its missing the trans harness part of it.
I can not find any info on this. Only people using the s13 dohc parts to get it to work.
Toplevel4ever 06-23-2013 07:49 PM
Noone has insight on what wires to the ecu need power for it to turn over? I just need to get the thing running. Im not worried about emission things at the moment.
please help!!
I have ecu pinout diagram, and fsm schematics of wiring but just cant get it to turn over.
Toplevel4ever 06-26-2013 10:19 AM
I think i have power to the ecu where i should. I'm not getting any fuel out of the injectors or i am not getting spark either. Im getting fuel to the rail tho. I see 12v to the injectors but nothing is coming out.
HELP PLEASE! :-)
Link 06-26-2013 10:30 AM
welcome to the most unhelpful place on the internet.
Toplevel4ever 06-26-2013 10:43 AM
lol awesome!!!
Chuki_KA24e 06-26-2013 10:47 AM
When I did a De swap into my 90' last winter we had the same problem. Crank all day long till the battery is dead but no start. Turns out there is a "starter enrichment something or other" that you need to jump the wires on so it will fire up. Let me go check what color it is, since I'm ghetto and still have my Ecu sitting on my floor lol...
Edit*
Ok it's the orange wire, no stripe, just orange. Make sure it's connected between your Ecu harness and dash harness up behind your glove box. The ecu and harness that came with my De had the dash harness part cut off so, I had to hook things back up. That happens a lot apparently.
Link 06-26-2013 10:48 AM
rofl dude that made me laugh.
Toplevel4ever 06-26-2013 11:16 AM
Edit*
Yes i have that one connected already. My chart says thats for ign/start and it gets 12v when the ign is turned on.
Chuki_KA24e 06-26-2013 11:25 AM
Well shit, I'm fresh out of useful input...
Toplevel4ever 06-26-2013 11:36 AM
lol well thanks for that anyways. I appriciate all the help i can get. Im trying to avoid spending a few hundred more dollars on dohc parts from a 91-93 and avoid this whole obd2 crap.
Toplevel4ever 06-26-2013 12:07 PM
I realized i dont have a map sensor connected. I wonder if this would be a problem. Altho i believe the map sensors on these cars are more for emmisions and not fueling.
Driftwire 07-08-2013 05:48 PM
I having the same problem except my ECU will not turn on and im using all 91-93 DOHC parts
